Ignition firing order?
65,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
ZAIM REXHA
I suppose it starts with the first cylinder. Which position is it?
How is the following order for the 6 cylinders?
Sep 2, 2024 at 6:45 PM
  • 55,561 POSTS
Sure, here is the engine ignition system firing order. Check out the images (below). Let us know if you need anything else.
Sep 3, 2024 at 2:32 AM
ZAIM REXHA
Thank you very much, that's all for the moment. I will ask again.
Sep 3, 2024 at 5:15 AM
  • 55,561 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Sep 3, 2024 at 5:16 AM
