ignition timing (knocking sound on pressing the gas pedal)
190,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
ENVOYAGER
Engine redone recently by a garage mechanic, starting is bit sluggish on cranking and then the engine starts on idle.After the temp reaches normal and AC is turned on, engine idling speed starts to vary, at times tends to stop. At this time when I turn the steering wheel , the engine cuts out. I got it checked by a computer guy and he said the timer on the camshaft is stuck on the advanced side. Its been several days I am stuck with this problem and unfortunately the local parts supplier has run out of stock for this part.( I don't know the correct part name )
Please help me out .
Aug 26, 2014 at 5:01 AM
HMAC300
  • 48,601 POSTS
it may be a bad distributor a mechanic has to set that up I think what the guy meant that the cam to crank sensor schyncronization is out of whack and you need apro style scanner to fix it. However some of these hav ebad dist gears so that should be checked as well.
Aug 26, 2014 at 5:07 AM
ENVOYAGER
Thanks for your quick response
En
Aug 26, 2014 at 5:30 AM
HMAC300
  • 48,601 POSTS
sorry I goofed a 4.2 doesn't have dist but it's still the cam to crank sensor problem.
Aug 26, 2014 at 5:48 AM
