Okay. How sure are you that you are getting injector pulse? Clearly, we have made an assumption somewhere that led us down the wrong path.
Go to fuse M21 in the TIPM which is under the hood, and check for power on both sides of the fuse when you are in key on and cranking the engine. This is the ASD relay that feeds this fuse. The relay also feeds the injectors so if we have no injector pulse then the relay could be the issue.
Otherwise, we should have power on both sides of the fuse which means the coils are getting 12-volts, but the PCM is not commanding the high voltage spike. If that is the case, then there is another reason that the PCM is preventing spark.
However, if the PCM is not the issue and you put a crank sensor in it then I have to suspect that we have an issue with getting power to the coils through this fuse.
Images (Click to enlarge)
Jun 24, 2022 at 4:45 AM
