ignition switch will not turn on
510,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
DILL-11
  • 126 POSTS
Switch stuck will not turn on or back truck in park. No buzzer sound with key in switch.
Aug 1, 2017 at 12:39 PM
  • 55,748 POSTS
It sounds like the ignition lock has gone bad which is common. Here are some guides to help you get the problem fixed.
You will need to have the key programmed at the dealer.
Cheers, Ken
May 4, 2021 at 6:31 AM
