Ignition switch replacement
156,000 MILES • 4 CYL • 4WD • AUTOMATIC
CHEYAN68
Dad replaced new ignition switch in my vehicle. Put the key in that came with the part, used my original key with code and stuck it to the side with the chip so it could read the code. Started the car but only stayed running for a couple seconds and shut off. Key light blinking on dash also.
Jun 22, 2018 at 12:58 AM
  • 55,746 POSTS
Yes, you cannot have the RF chip outside of the RF antenna which is around the ignition lock. Use must use the right key or open the old key and the new key and swap the chips.
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Jun 23, 2018 at 6:44 AM
