Ignition switch problem
2001 PONTIAC GRAND PRIX
50,000 MILES • TURBO • AUTOMATIC
DEE44
the ignition switch will not turn all the way off and sometimes the key will not come out either. now I have to disconnect the battery to the car to make sure the car is off. how do I get the ignition switch to turn all the way off? Please help. Thanks
Mar 11, 2017 at 2:08 PM
WRENCHTECH
  • 20,761 POSTS
It has a park lock solenoid that prevents you from locking the steering column if it is not in Park so that solenoid or the signal to it may be having a problem. #2 is the solenoid. https://www.2carpros.com/images/external/85097430.gif
Mar 11, 2017 at 8:37 PM
