You have to remove the lock cylinder, it is pretty simple to do, first you should see a little hole somewhere on the lock cylinder housing, turn the key to the on position and insert a paper clip in the hole and push while pulling out the lock cylinder.
The switch is held in place by I belive two bezels.
SPONSORED LINKS
Saturday, December 22nd, 2007 AT 8:26 AM
