Ignition switch does not turn
120,000 MILES • 1.4L • 6 CYL • FWD • AUTOMATIC
CMAYO22
Ignition switch does not turn and steering wheel is locked.
Jun 21, 2017 at 12:07 PM
HARRY P
  • 2,292 POSTS
Sometimes the steering lock mechanisms can bind up the ignition and keep it from turning. Turn the wheel in whichever direction the front wheels are pointed as hard as you can and try turning the ignition. Let us know if that works, or if you have already tried that.
Jun 21, 2017 at 12:33 PM
CMAYO22
I already tried your suggestion and it did not work. I also sprayed lubricant in the key hole and tapped the key/ignition-switch with the same results. The key did not turn and the steering wheel did not release. Any other suggestion? Thank you for your cooperation!
Jun 21, 2017 at 4:47 PM
HARRY P
  • 2,292 POSTS
I guess you have probably jiggled the wheel back and forth and tried turning the key too. I will see if I can think of anything else to try.
Jun 22, 2017 at 8:04 AM
  • 55,721 POSTS
It sounds like the tumbler has gone bad which is common for your cars age. You can get the replacement from Amazon for about $60.00
https://www.amazon.com/gp/product/B000E671FM/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B000E671FM&linkId=444738586a16b2aa0de1e6cd2eb3eda6
The only tough part will be getting out those rivets but if you use a sharp chisel and dig in from the side to loosen it will not be to bad.
Cheers, Ken
Jun 22, 2017 at 9:29 AM
