Ignition switch
250,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DAVIDSMITHIII
Ignition switch and lock have been replaced apx 4 to 5 times. Last time both of them from knects. Seams this time the spring back is gone. I put a hot wire the first time this happened so I could start the start the van. So I was able to start the van. Van is a SE model. Would like to know how to by pass entirely. I'm an electrian. A scamatic of how to do would be great.
Dec 26, 2019 at 8:09 AM
  • 110,248 POSTS
I'm not sure exactly what you are asking. Do you want to bypass the ignition switch itself?
I attached a portion of the power distribution schematic showing the ignition switch. If you want the entire power distribution schematic, let me know.
Dec 26, 2019 at 10:55 AM
