Ignition switch
60,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LUKE OLSEN
Van will not start (random). the engine cranks over, but no spark. try again later, and it may start.
Apr 30, 2018 at 12:18 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It could be the ignition switch. You should test the wire going to the ignition coil for voltage when the times it does not start.
Apr 30, 2018 at 12:24 AM
LUKE OLSEN
there is power to the coil. just a test light, though. i do not know the voltage.
Apr 30, 2018 at 12:53 AM
LUKE OLSEN
last fall I accidentally grounded the ignition wire, and then repaired the fusible link at the starter.
Apr 30, 2018 at 12:57 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Are you doing this test while there is spark or when there is no spark? Because you have to wait until you have no spark.
Apr 30, 2018 at 2:02 AM
