Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Van
Electrical
Ignition Switch
Ignition switch
1986 CHEVROLET VAN
60,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LUKE OLSEN
MEMBER
Van will not start (random). the engine cranks over, but no spark. try again later, and it may start.
Apr 30, 2018 at 12:18 AM
PATENTED_REPAIR_PRO
Experienced Mechanic
It could be the ignition switch. You should test the wire going to the ignition coil for voltage when the times it does not start.
Apr 30, 2018 at 12:24 AM
LUKE OLSEN
MEMBER
there is power to the coil. just a test light, though. i do not know the voltage.
Apr 30, 2018 at 12:53 AM
LUKE OLSEN
MEMBER
last fall I accidentally grounded the ignition wire, and then repaired the fusible link at the starter.
Apr 30, 2018 at 12:57 AM
PATENTED_REPAIR_PRO
Are you doing this test while there is spark or when there is no spark? Because you have to wait until you have no spark.
Apr 30, 2018 at 2:02 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
