Can I start my car without the ignition switch
16,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
HENRY STUCK
I bought this car with no ignition. Is there a way I can start my car and or even drive it until I can get a new ignition switch?
Jun 18, 2020 at 11:42 AM
The short answer for this vehicle is no. Your vehicle has what is called a SKIM key and it is required to turn the ignition and send a signal to the module that recognizes it as a valid key and then this sends a signal to the PCM to say it is okay to start the vehicle. Then the PCM turns on the injectors and coils.
Let us know if there is a specific issue we can help figure out and we can go from there. Thanks
Jun 18, 2020 at 12:27 PM
