Ignition switch
150,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DMILVAE
  • 11 POSTS
When you turn the ignition switch the doesn't spring back and also will not start with the key.
Sep 12, 2019 at 10:39 PM
If this is the issue then you have an issue with the cylinder portion of the ignition cylinder.
I attached the directions on how to remove this.
The key not returning is most likely the cylinder portion of this but the not starting at times is most likely the actual ignition switch. I included the complete instructions. Please let me know if you have questions. Thanks
Sep 13, 2019 at 11:54 AM
DMILVAE
  • 11 POSTS
Thanks for your help.
Sep 15, 2019 at 2:27 AM
You are welcome. Thanks for using 2CarPros. Please come back and post a new question if you have other issues. Thanks again.
Sep 15, 2019 at 2:28 AM
