Ignition relay
50,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
MORGANMCK7
I was trying to diagnose why my girlfriend's radiator fan wasn't coming on. Thought the easiest way would be checking the relays. I was accidentally working with the ignition relay instead of the fan relay. I asked her to start the car while the ignition relay was out (not knowing it was this relay of course). The engine failed to start of course. Put it back in and it started. Next time she drove it the engine light came on. I really hope I didn't mess anything up. Can someone please help my sanity while we are awaiting the day we take it to the shop? Side note: The reason why I was checking out the radiator fan is because the AC hasn't been working and one of my friends (who is much more handy with cars than me) thinks the radiator fan isn't coming on.
Aug 18, 2019 at 10:25 PM
SCGRANTURISMO
  • 4,897 POSTS
If the Malfunction Indicator Lamp (MIL) or "check engine" lamp illuminated then you will need to pull the Direct Trouble Code (DTC) for us. Here is a link below for you to go to on how to do that:
Please go through the guide, pull the DTC(s) for us and get back to us with what you are able to find out. We will go from there.
Thanks,
Alex
2CarPros
Aug 19, 2019 at 7:54 AM
