Ignition problems
10,000,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
RAYMONDBECKHOLT
  • 6 POSTS
Wont start and replaced coil,and it's fireing but won't start. And back fires
Jan 29, 2016 at 4:48 AM
WRENCHTECH
  • 20,758 POSTS
Have you done anything else like mess with the wires, dist cap or move the distributor?
Please post an engine size when you return.
Jan 29, 2016 at 5:25 AM
RAYMONDBECKHOLT
  • 6 POSTS
I took off cap and made sure was OK. But had wires numbers and numbers on distubuter. So all wires was put back as diagram. Did not move distributer position
Engine is a 8 cylender 5.7 l
Jan 29, 2016 at 5:34 AM
RAYMONDBECKHOLT
  • 6 POSTS
I also did this same thing a week ago and ran. It seems if you pull distributor and clean it runs for a day or to and refuses to start again but now it's also back fireing thru carb
Jan 29, 2016 at 5:46 AM
WRENCHTECH
  • 20,758 POSTS
Pull the distributor and clean it?
Jan 29, 2016 at 5:51 AM
RAYMONDBECKHOLT
  • 6 POSTS
I did and now it cranks and when it does hit it backfires and won't start
Jan 29, 2016 at 5:55 AM
WRENCHTECH
  • 20,758 POSTS
Did you actually remove the distributor?
Jan 29, 2016 at 6:13 AM
RAYMONDBECKHOLT
  • 6 POSTS
No just cap and rotor
Jan 29, 2016 at 6:14 AM
WRENCHTECH
  • 20,758 POSTS
If I was to guess at this I would say you have a cracked distributor cap. You won't necessarily be able to see it even if you know what to look for. I would replace the cap and rotor and verify your firing order.
Jan 29, 2016 at 7:14 AM
RAYMONDBECKHOLT
  • 6 POSTS
Sorry did not realize I sent it more than once .on a cell phone. OK thank you I will try to replace them
Jan 29, 2016 at 7:17 AM
  • 55,781 POSTS
Did you find out what happened?
Apr 23, 2016 at 12:03 PM
