Will not turn over, dash warning message "key not detected"
140,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ANTHONY52274
When I put the key in the ignition and try to crank it all the lights and electrical stuff turn on, but it will not turn over. It says key not detected.
Jun 30, 2022 at 2:10 PM
  • 55,770 POSTS
This means the chip in the key is not working or the car has forgotten the key code. Can you try your extra key to see if it works? I would remove the negative battery cable and touch it to the positive terminal for one minute to clear and reboot the system to see what happens.
If that does not fix it let's do a CAN scan which is the future of automotive repair, you can get a CAN scanner from Amazon for about $30.00. Here is a video to show you how and a link to a scanner from Amazon. This will tell us what is happening.
https://youtu.be/u-4syLc-ifQ
and
https://amzn.to/3OpAotj for the scanner
Jul 1, 2022 at 11:13 AM
