ignition or fuel regulator/pump?
144,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WILLIE HURLOCKER
  • 83 POSTS
one of you told me your mother in-laws Dodge minivan was doing the same thing a while back. my wagon's ignition when i turned would do nothing unless i let it turn back about halfway then turn it back on and start. not every time about two times in last 6 months! Alright it's still shutting off sometimes when i slow down to stop or turn into a parking spot and if i hurry and put it in D and start it, it starts but goes to limp mode. then i shut it off it put it back in Park then wait for 5 seconds. start it and normally put it in D it drives fine! it's done this 2/3 x past 6/7 months. could these two things be one or separate no codes well had one a couple weeks ago for p0420 cat slow response but cleared it and hasn't come back? thinks it's the fuel pressure regulator/pump or the ignition switch. crank and cam sensors are new. I've got a vacuum pump but not the right connector.
Apr 21, 2024 at 1:12 PM
  • 110,251 POSTS
It sounds like it could be related to the ignition switch itself. When you scanned for codes, did you scan the engine can-bus system? If the transmission went into limp mode, there should be codes stored.
If you haven't, here is a link explaining what I'm referring to. Let me know if you have done this or if it is something you can do or have done.
Apr 23, 2024 at 11:03 AM
