Engine will crank but not start
250,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CHRYSTYG6972
It has new fuel pump, plugs and wires, distributor cap and rotor and full gas tank but still won't start.
Nov 10, 2020 at 4:22 PM
Good morning,
Can you hear the fuel pump run when you turn the key to the on position?
When cranking, do you have a spark to the spark plugs?
Can you check the compression to be sure the valve timing is correct?
You will have an issue with one of these systems.
Let us know what system is not working so we can narrow the area of failure.
Nov 10, 2020 at 5:27 PM
