Not getting spark from one coil pack?
132,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
KOOTER 35!
  • 6 POSTS
However, I am getting spark from the other two. Could it be the module or bad coil pack? Replaced the coil pack with a used one but still no spark from that pack but other packs are firing.
Oct 8, 2022 at 7:41 AM
  • 110,244 POSTS
Switch a working coil on the vehicle with the one in question to see if the problem still exists. If it does, then we have to check a few things to determine the cause of the issue. If it does change and you get spark from the number 1 coil, replace the coil. If the same thing happens, chances are it is the module.
Let me know what you find.
Oct 8, 2022 at 3:16 PM
KOOTER 35!
  • 6 POSTS
Thank you, Joe. Will do, I picked up a new coil today so we will see what happens. I always thought that if it was the module that it would affect all coil packs however, I was informed that each pack runs off of its own circuit within the module board. But yeah, I will let you know and again, thank you.
Oct 8, 2022 at 3:25 PM
  • 110,244 POSTS
No problem whatsoever. Also, that is correct. You can have one that fails as a result of the module itself.
Let me know what you find and hang in there. We'll get it fixed.
Oct 8, 2022 at 3:28 PM
KOOTER 35!
  • 6 POSTS
I'm hopeful because these 3.1 are a pain in the a## to get too!
Oct 8, 2022 at 7:04 PM
  • 110,244 POSTS
I saw this response from you and was wondering if you have been able to make any progress. Were you able to get spark from coil one?
Oct 9, 2022 at 1:16 PM
KOOTER 35!
  • 6 POSTS
Going to work on it tonight after work. I will let you know.
Oct 10, 2022 at 12:03 AM
KOOTER 35!
  • 6 POSTS
Hey Joe, the module fixed it. Thanks for the help and I learned something along the way.
Oct 10, 2022 at 10:24 AM
  • 110,244 POSTS
You are very welcome. I'm glad to know you got it fixed. We all learn something new every day. Pick the things that benefit you. LOL
Take care of yourself and please feel free to come back anytime in the future if you have questions. You are always welcome here.
Oct 10, 2022 at 12:41 PM
