Ignition lock cylinder will not turn?
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
HONDABOBBY
My ignition lock cylinder has gone bad. Accepts key but will not turn. Can i use one from a salvage yard if i change the entire steering column?
Oct 8, 2022 at 12:07 AM
  • 110,248 POSTS
You won't be able to use one from a salvage yard. If you are able to get a good one, it will need to be programmed for the immobilizer.
Are you certain the cylinder is bad?
Take a look at this link:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Oct 9, 2022 at 9:41 AM
