Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Odyssey
Electrical
Ignition Switch
Not Turning
Ignition lock cylinder will not turn?
2010 HONDA ODYSSEY
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
HONDABOBBY
MEMBER
My ignition lock cylinder has gone bad. Accepts key but will not turn. Can i use one from a salvage yard if i change the entire steering column?
Oct 8, 2022 at 12:07 AM
Experienced Mechanic
You won't be able to use one from a salvage yard. If you are able to get a good one, it will need to be programmed for the immobilizer.
Are you certain the cylinder is bad?
Take a look at this link:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Oct 9, 2022 at 9:41 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
