When replacing the ignition lock cylinder and not the whole assembly, do I still need to get the key programed?
200,000 MILES
GINA BUSBY
Okay, I bought a new ignition lock cylinder with the key. When I change the cylinder and not the whole assembly. Do I still need to get the key programed? Okay I changed the ignition lock cylinder and the car keeps digging but the key won't turn. I read that after market cylinders don't meet flush so the right stuff isn't connecting to tell my car to run. So I'm assuming I need to get the whole assembly instead. So my question is if I get the whole assembly with the coded key once I change it do I have to get anything reprogramed or will my car just start normal again?
Aug 6, 2023 at 3:57 AM
  • 55,758 POSTS
You will need to have its codes, I would get the part from the dealer so it will come pre-coded or have a mobile locksmith come out and recode the key. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 7, 2023 at 4:37 AM
