I am trying to replace the ignition lock assembly due to lost keys. My question is, does one have to remove the lock cylinder from the assembly in order to remove the Park Interlock cable? I cannot get the cable out of the ignition lock assembly. I have depressed the park cable locking tab on the interlock cable and the cable only moves back about 1/16 of an inch. I have not tried using force yet due to not knowing how it is held in. If the lock cylinder has to be removed in order the extract the park locking cable, then how does one remove the lock cylinder without having a key?
Apr 26, 2020 at 8:59 AM
