Ignition lock
222,124 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CHRIS SMITH2
Key goes into ignition but will not turn.
Feb 26, 2018 at 3:21 AM
  • 55,721 POSTS
It could be you have the steering wheel pressed against the lock. Here is a guide to help you see whats going on:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If okay then the lock will need to be replaced here are guides below to help you see what you are in for when doing the job. I think you can get the ignition lock from Amazon or Rock Auto.
Check out the diagrams (below).
Please let us know what you find.
Cheers, Ken
Feb 28, 2018 at 2:54 AM
