Will not start after replacing ignition leads
236,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KELLY BLACKMAN
I have just changed the two ignition leads and now car will not start
Jul 30, 2018 at 5:52 PM
  • 55,694 POSTS
Did it run with the old stuff? Can you remove one if the leads to check for spark? Here is a guide to help you test for spark look toward the bottom:
Cheers, Ken
Aug 1, 2018 at 10:53 AM
