Ignition key turns on, but dashboard light does not turn on?
23,455 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MALLYBOY
  • 329 POSTS
When you turn the ignition to the on position, it will turn but the dashboard light does not come on. I have checked all fuses and all checks okay, what could be the cause?
May 8, 2024 at 1:25 PM
  • 110,251 POSTS
Does anything electrical work on the vehicle? For example, do the brake lights turn on when you press the pedal?
Do me a favor. If nothing is working, check to see if the fuses in the CJB have power to them.
See pic below.
May 9, 2024 at 1:07 PM
MALLYBOY
  • 329 POSTS
No electrical work done.
May 9, 2024 at 5:18 PM
  • 110,251 POSTS
If nothing is working, confirm there isn't a ground problem from the battery. Additionally, check if any fuses in the CJB fuse box have power.
May 10, 2024 at 12:35 PM
MALLYBOY
  • 329 POSTS
There are power on the most fuses there.
If you plugin the battery terminal, the two headlamps will lit as if there's a module that is not communicating.
May 10, 2024 at 3:32 PM
  • 110,251 POSTS
If the CJB doesn't have power to everything, chances are that is where the problem is. I would remove it and inspect the wiring behind it. The headlamps could be getting power via a short to power.
If you want, connect the battery so the lights turn on. Remove the fuse for the headlamps and see if they turn off. If they don't, we have a short to power likely in the box or behind it.
May 11, 2024 at 12:38 PM
