Ignition key cylinder removal
260,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
PERCYIROGUE
Tried removing the ignition lock cylinder so I can replace it. But the old one is stuck in the steering column.
Mar 17, 2022 at 1:17 PM
WENDY W
  • 86 POSTS
I've attached removal and installation procedures below for both functional and non-functional ignition lock cylinders. Please remember to disconnect the negative battery cable before you begin.
You may also find these repair guides to be useful:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If there's anything else we can help with, please let us know.
Thanks, Wendy W.
Mar 18, 2022 at 4:57 AM
