Ignition key
220,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
PEGGY FULTON
Sometimes the ignition key will turn turn, to start engine. Is there some way to repair without having to buy a new igntion?
Jul 7, 2019 at 12:21 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If you have a spare key, try it. I have seen the keys actually wear out and cause this. If it doesn't help and you are still unable to turn the key in the tumbler, the switch will need replaced.
If you find it does need replaced, here are the directions. The attached pictures correlate with the directions.
______________________________
Non-Functional Lock Cylinder
Vehicle Starting and Charging Sensors and Switches - Starting and Charging Ignition Switch Ignition Switch Lock Cylinder Service and Repair Procedures Non-Functional Lock Cylinder
NON-FUNCTIONAL LOCK CYLINDER
Removal
WARNING: Always wear safety glasses when repairing an air bag Supplemental Restraint System (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: Carry a live air bag module with the air bag and trim cover pointed away from your body. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: Do not set a live air bag module down with the trim cover face down. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: After deployment, the air bag surface can contain deposits of sodium hydroxide, a product of the gas generant combustion that is irritating to the skin. Wash your hands with soap and water afterwards.
WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury.
WARNING: Air bag modules with discolored or damaged trim covers must be replaced, not repainted.
WARNING: Vehicle sensor orientation is critical for proper system operation. If a vehicle equipped with an air bag Supplemental Restraint System (SRS) is involved in a collision, inspect the sensor mounting bracket and wiring pigtail for deformation. Replace and properly position the sensor or any other damaged supplemental restraint system (SRS) components whether or not the air bag is deployed.
WARNING: To avoid accidental deployment and possible personal injury, the backup power supply must be depleted before repairing or replacing any front or side air bag supplemental restraint system (SRS) components and before servicing, replacing, adjusting or striking components near the front or side air bag sensors, such as doors, instrument panel, console, door latches, strikers, seats and hood latches.
The side air bag sensors are located at or near the base of the B-pillar.
To deplete the backup power supply energy, disconnect the battery ground cable and wait at least one minute. Be sure to disconnect auxiliary batteries and power supplies (if equipped).
1. Disconnect the battery ground cable and wait at least one minute.
2. Remove the steering wheel.
pic 1
3. Twist off the cap from the ignition switch lock cylinder.
pic 2
4. Remove the ignition switch lock cylinder.
^ Use a 1/8-inch diameter drill bit to drill out the lock cylinder retaining pin.
^ Use a 3/8-inch diameter drill to drill down the middle of the ignition lock key slot until the ignition switch lock cylinder breaks loose.
^ Remove and discard the ignition switch lock cylinder and drill shavings from the steering column.
pic 3
5. Remove the bearing retainer.
pic 4
6. Remove the bearing and the gear.
^ Thoroughly clean all drill shavings from the steering column and inspect it for damage.
Installation
pic 5
1. NOTE: Use a new ignition switch lock cylinder.
Follow the removal procedure in reverse order.
^ Verify ignition switch lock cylinder operation.
_______________________________
Let me know if you have other questions or need help.
Jul 7, 2019 at 12:39 PM
