ignition key
15,000 MILES
BURNLEY FAN
Ignition key keeps getting stuck what can i do
Jan 22, 2016 at 10:33 AM
ED-WEEZY21
  • 248 POSTS
A couple you might try that has worked for me in the past. Try spraying a little WD-40 or something equivalent right into the key cylinder. This should oil up the inside and prevent it from binding. Another thing is to make sure that the key itself isn't bent, twisted, damaged, or just worn out too much. Ive owned a vehicle where my key was slightly twisted causing me problems. I made a new key and it fixed my issue.
Jan 23, 2016 at 8:52 AM
ED-WEEZY21
  • 248 POSTS
If these things don't work, then unfortunately, the key cylinder will need to be replaced.
Jan 23, 2016 at 8:53 AM
