Ignition issue
1,000,000 MILES • 5.0L • V8 • 4WD • MANUAL
RICKB8479
  • 21 POSTS
Been reading a post between the medic and cfengineer. I have the same issue.
What i know so far:
Was running fine and just died
84 cj7
79 304 (I think)
Ford ignition not prestolite
New coil (external resistor)
New ignition module
New distributor
5v at coil with ignition on
11v at coil while cranking
Pulsing spark to ground from coil while cranking
Spark at number one plug only at first crank and when released
No spark during extended cranking
Fuel present
Timing close to correct
Ignition switch has been abandoned
In its place a switch for ignition and a momentary switch for start. Been working this way for years.
HELP
Mar 26, 2017 at 6:54 AM
CJ MEDEVAC
  • 11,000 POSTS
Thank Gosh!
Haven't seen a CJ on here in forever!
Let me digest this a little.
Have you had that ignition module tested at the parts store?
I learned long ago, new ones can be bad too!
If you get a new one, test it before you leave, do the test 5-8 times in a row!
Have you had the distributor out?
The Medic
Mar 26, 2017 at 9:31 AM
CJ MEDEVAC
  • 11,000 POSTS
Is this a new buddy for you?
Has it ran for you?
The Medic
Mar 26, 2017 at 9:33 AM
RICKB8479
  • 21 POSTS
Yes had it tested. Yes distributor is new. Removed old one after marking orientation of advance pot and rotor. Yes its new to me been running for me for 6 mos. Ran for previous owner 4 years. I read one of your previous posts and did what you said there are several of your questions answered in my first post. I am glad it was you that found it.
Mar 26, 2017 at 9:42 AM
RICKB8479
  • 21 POSTS
Btw the "I think" refers to the year model of the engine. I know its a 304
Mar 26, 2017 at 9:44 AM
CJ MEDEVAC
  • 11,000 POSTS
Just as a test,
Try this
Positive Battery to Positive Coil
Then attempt a start.
If it coughs into action, removing the wire should kill it.
WATCH OUT FOR THEM PESKY MOVING PARTS!
If things are scarce, you can chop up a cheap 6 foot household extension cord to do it.
Lemme know what happens!
Been working on "Willys" steering gear all night, getting the slop out, midnight-thirty here, must work tomorrow!
See pics below
The Medic
Mar 26, 2017 at 2:32 PM
CJ MEDEVAC
  • 11,000 POSTS
While it is cranking, does it spit and sputter and sorta 'wants to' bust off and run or it does it just give you dry over and overs? (then nothingness when you let go of the button)
The Medic
Mar 26, 2017 at 2:39 PM
RICKB8479
  • 21 POSTS
Nothing with wire between battery positive and coil positive.
The onlt time it acts like it wants to start is some times when you let off the button. (One cough)
Mar 27, 2017 at 12:59 PM
CJ MEDEVAC
  • 11,000 POSTS
OK!
Sounds like "I" Terminal is not working right. (may or may not have a bearing on the situation at hand)
If "I" was working 'right', it would run while cranking, die when released (if Ignition were not supplied from the key 'ON' position)
My hypothesis at this point is Something is not hooked right or is grounding out when you turn it 'ON' ('I' might be fine, but the other end is cancelling it out.
I'll sling this out - You have the Ignition Module is grounded well?
If you disconnect the Ignition Switch
Hook the Pos battery back to Pos Coil
Give it a try
Better results?
This is not the original engine is it?
I'm sending you some partial diagram that may help you look at the wiring
Yeah, it's from the 258, I want you to see if all of the wires (not the firewall) go where they should, are any missing? Do any hook to something not shown in the diagram?
Can you send pics of tour engine, top, sides?
I'm here for the long haul, try to bear with me! I'll keep going as long as you will!
The Medic
Mar 29, 2017 at 10:17 AM
RICKB8479
  • 21 POSTS
Ok. Lets go through this again.
Facts:
1984 cj7
1979 304v8
Ran for 4.5 years and just died
Replaced coil (external resistor required)
Replaced ignition module (tested good two different places)
Replaced distributor ( in time more or less)
5.6 volts at coil in on position
Wont run in either position
One Spark from coil to ground when start button depressed
One spark from coil to ground when released.
Resistor wire in place
One wire from splice at fire wall to exciter field of alternator not shown in diagram you sent me
Removed that wire temporarily and nothing changed
Ran wire temporarily fron batt+ to coil+ no change
Checked ground at module. Ok
What am I missing?
Can i get you on the phone while I test?
Apr 22, 2017 at 6:30 AM
CJ MEDEVAC
  • 11,000 POSTS
I'll PM you after another check or two.
"Replaced distributor ( in time more or less)" (Means what?)
Mr. Distributor has been out/ partially out of his hole during this sickness?
This may be a review, dumb stuff does happen!
At the bottom of each of our responses is a Date/ Time
In the link I'm sending, look for "MY ANSWER" on MONDAY, NOVEMBER 23RD, 2015 AT 6:43 PM
https://www.2carpros.com/questions/no-spark-from-coil-to-distributor
(This written when I just used all CAPs, 'cause it was EZer, got peoples attention! They tend to frown on doing that now, otherwise I woulda just copy and pasted to you, I really don't wanna rewrite the whole deal!)
Lemme know how this goes!
Some good pics of/ around the engine might help.
We will get you going!
The Medic
Apr 22, 2017 at 7:34 AM
RICKB8479
  • 21 POSTS
Yes as I said I replaced the distributor. I clocked the rotor and the advance pot before removal and reinstalled in the ecact same positions so the timing is close to correct. I listed everything i have done or confirmed in the previous post. I have traved all the wires now and drawn you a diagram. There are other pics too.
1. Diagram
2. Splice at fire wall
3. Module
4. Module connector
5. Wires out of loom
6. Duplicate
7. Distributor connector
8. ? Something inline to coil-
9. 2 oranges and a purple through passenger side firewall.
Any of this helpful?
Apr 22, 2017 at 8:20 AM
CJ MEDEVAC
  • 11,000 POSTS
Good pics!
How 'bout some of the distributor and the ignition module. But most of all, their connectors/ connections. Definitely has some add on wiring (that may have worked in the past- maybe could be improved)
I know you think I'm not hearin' what you have done!
Doing this online is more of a challenge, even in person sometimes this'll blow one's mind. The modifications to one throws a twist in the whole deal.
How about doing the TDC thing (# 1 plug screwed in a turn or so) listen for hiss while turning with a ratchet. Continue around till the timing marks are on "0".
AS said better in the LINK I SENT!
Then snatch the distributor cap off
Verify that the rotor button is pointing at #1 spark plug wire.
IF this ain't right, you will still get spark, just at the wrong time!
10 minutes now may save you a lot more time later!
We have to methodically eliminate factors.
The Medic
Apr 22, 2017 at 9:36 AM
RICKB8479
  • 21 POSTS
Any clue whats under the dash on the passenger side. ??? Too dark for pics now. Stand by. Agter resding many of your posts I cant figure why i have no spark while cranking. ??? I have 11v at the coil. I understand that if the timings out it won't run but it would backfire and carry on. ???? Its also odd that I get a spark when depressing the start button and when releasing it. What is that black thing in line on the green wire. I have been trying to do this systematically based on other if your posts. Do you have a procedure to follow step1 through step? I only get to work on it in spurts so it is difficult to do this one post at a time.
Apr 22, 2017 at 11:15 AM
RICKB8479
  • 21 POSTS
Btw I performed the test on the distributor pick up as you posteded. s goodsd
Apr 22, 2017 at 11:20 AM
RICKB8479
  • 21 POSTS
Wow. The pick up is good. Thanks.
Apr 22, 2017 at 11:21 AM
CJ MEDEVAC
  • 11,000 POSTS
I've spent a good while making this for you.
That's why I have not responded.
Lemme know if this helps, I found the basic diagram on the net, you'll see my erasing and adding of the wires and explanations. Post any un-sure-ities!
Alternator thing is new on me! Maybe a condenser for the radio? Fusible link? Does the juice flow thru it?
The Medic
Apr 22, 2017 at 12:13 PM
CJ MEDEVAC
  • 11,000 POSTS
I reckon I cut the bottom off.
Info lost there
IGN MODULE "WHITE WIRE" came down, then over the module, then to the bottom, ran left, then up the left side and tied into the "S" wire (BLUE- you can see that end of the white wire) These two wires connected at the firewall (look at one of my 1st diagrams from way up above).
News on TDC and rotor position at distributor cap test?
The Medic
Apr 22, 2017 at 12:25 PM
RICKB8479
  • 21 POSTS
No tdc till tomorrow. Ill look at the white wire them too.
Btw. Thats not my distributor. Cap is one piece on mine. If you look at the pic of my module connector youll see it had no purple but it does have purple on the module. The purple wire connected to the distributor is coming thru the firewall on the passenger side. Thats what makes me ask whats back there.
I think we are starting to get somewhere on the ignition at least it has become apparent that we are talking apples and oranges
Thanks for the help. more tomorrow.
Apr 22, 2017 at 1:19 PM
CJ MEDEVAC
  • 11,000 POSTS
pics of dist/ module connectors
Pic below is 1979 diagram from a manual
I scanned it, colored in Microsoft Paint
I colored the wires best I could (so I could understand the ones with color tracers, color of the tracers was not given)
The 258 and 304 share the same diagram. 304 being in the upper left corner and 258 is directly below it.
You will see the Battery for both. East and West and South of the 2nd battery is mostly the 258. Sorta disregard the stuff pertaining to the 258 (it is so close to the 304 wiring).
1st pic is both engines
I cropped 2nd pic to show more 304
I feel sure the 1984 Ghost wire goes into the firewall/ thru the computer/ back out.
Need to eliminate the ghost stuff and insure the wires go directly from one part to the other with no 'goodies' in-between.
Pic 3, I also had the 2 pieces of my home-colored diagram blown up at Office Max. I overlapped them correctly, taped them in place, then Office Max laminated it for me. It's darn big/ EZ to trace wires/ fast to find stuff.
The Medic
Apr 22, 2017 at 2:22 PM
CJ MEDEVAC
  • 11,000 POSTS
I have no idea why the 1st pic did not show above, it was loaded.
2nd pic is the main one anyway!
The Medic
Apr 22, 2017 at 2:30 PM
RICKB8479
  • 21 POSTS
Distributor install correctly. Are you telling me theres a computer under the dash on the passenger side?
Apr 23, 2017 at 12:17 AM
RICKB8479
  • 21 POSTS
Ok.
Pic1. That appears to be spliced into the harness. Test plugs?
2. Thats where the orange from the module goes into the firewall and the orange and purple come out and go to the distributor
3. Distributor connector
4 and 5 module connectors
Apr 23, 2017 at 12:36 AM
RICKB8479
  • 21 POSTS
You'll notice the jeeps harness only has three wires on the connector to the module. No purple. Shown on my hand drawn diagram
Apr 23, 2017 at 12:42 AM
RICKB8479
  • 21 POSTS
Somehow I started a new string. Did you get the pics
Apr 23, 2017 at 1:22 AM
RICKB8479
  • 21 POSTS
This is the wiring diagram for my jeep ignition. What is an mcu
Apr 23, 2017 at 2:08 AM
RICKB8479
  • 21 POSTS
I found the mcu
Apr 23, 2017 at 3:28 AM
CJ MEDEVAC
  • 11,000 POSTS
I found the pic (full pic) I left it in "MS Paint" (see pics)
Page 2 showed with your pics!
Looks as though your Baby is a '84 with a '79 engine (knew this).
It (the engine) needs to be wired like a '79 to eliminate the new crap (computer)
WE ARE NOT GONNA JUST WHACK ALL THE WIRES OFF OF IT AND SLING IT IN THE WOODS!
We need to pretty much make it look like the diagram below, Actually my 2nd diagram below (same thing as 1st)
We will eliminate the module wires going in and out of the firewall (cut and cap off/ tape off these wires)
2nd diagram- see the Blue Wire? Follow it to (My/ 6 cyl) firewall. See that the white module wire connects to it at the firewall?
Now "hands on" your Blue Wire on the Jeep at the solenoid, Follow it to the firewall (this eventually runs to the IGN switch to "START"). The WHITE WIRE to the Module will hook onto it, anywhere! before it goes into the firewall. Pick a good out of the way anti-rats nest place to tie it in!
Your MODULE has 4 wires coming out? and 2 IN?
Send me a pic of the Module including the ends same with the distributor (end included)
I will use those pics to show you how to make nice splices and no crappy connections in order to keep all of this wiring in the engine compartment! (not going to the computer!)
We will get the missing wires back in place to match the '79 diagram.
I'll spend the time to help/ must keep wife's Honey-Dos at bay!
Ever use 3rd pic connectors?
Your Turn
The Medic
Apr 23, 2017 at 4:31 AM
RICKB8479
  • 21 POSTS
Cant see your reply
Apr 23, 2017 at 5:28 AM
RICKB8479
  • 21 POSTS
Got it
Apr 23, 2017 at 5:31 AM
RICKB8479
  • 21 POSTS
So i wred it up like you said it started right up. Thanks.
Now a new problem. After i shut it off and cleaned up all the wiring under the hood went to start it now it wont crank. Ill send a diagram of what i have tomorrow. Thanks again.
Apr 23, 2017 at 11:40 AM
RICKB8479
  • 21 POSTS
I guess at this point maybe you can just tell me how to rewire the start cicuit. What do you think? Thanks for all the assistance with the ignition. Real bummer that I have it running but now it won't crank.
Apr 24, 2017 at 1:07 AM
RICKB8479
  • 21 POSTS
the first pic is what I have now. the second pic is what I propose for a fix. Will it work?
What does the light blue actually do?
Apr 24, 2017 at 7:32 AM
CJ MEDEVAC
  • 11,000 POSTS
More like this!
See how I modified your pic below
The big thing is, the 4 wires from the IGN Module, go to their respective spots, and no where else along the way.
If you have to splice the Purple wire into place, do it! (Reason I asked if you had ever used the 'Piggy-Back' Splices in previous answer)
Cut loose anything that is not supposed to be there!
Blue comes from switch, when turned to 'start' it activates the solenoid allowing the pos battery cable to flow thru to the starter. When the key is released, the blue wire goes dead and the solenoid quits allowing the starter to turn (in hopes that the engine has started)
At the same time "I" gets full battery voltage, it overrides the low voltage resistance wire (only during cranking) This aids in 'start-up', as the starter is robbing the power at this time.
The Medic
Apr 24, 2017 at 11:38 AM
CJ MEDEVAC
  • 11,000 POSTS
Trying your pic again?
The Medic
Apr 24, 2017 at 11:39 AM
CJ MEDEVAC
  • 11,000 POSTS
OK,
Here's a diagram I made for a momentary contact push button switch.
I also added on where your Ignition Module "white wire" should connect.
The Medic
Apr 29, 2017 at 3:11 PM
