Ignition is locked, how do I unlock it?
90,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
FREISETARA
How do I get the ignition unlocked so I can start my van?
Sep 16, 2023 at 9:54 AM
  • 110,248 POSTS
It could be a few things causing this. However, keep in mind the lock cylinder that the key goes into may have failed and need to be replaced.
If you look through this link, it provides several different things to try. Take a look through them and let me know if it helps.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Sep 17, 2023 at 1:59 PM
