ignition failure
200,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
ALEFRAZIER
i recently changed out the ignition control sensor, coil packs, plugs, and wires due to problems I was having with the car. after I changed those parts I tried starting the vehicle and it would not start. I tried doing a ten minute relearn on key and took out crank sensor fuse for ten minutes as well and still nothing.
Jul 23, 2016 at 4:26 AM
HMAC300
  • 48,601 POSTS
If you replaced the ignition control sensor then it has to be programmed by a mechanic to your car.
Jul 24, 2016 at 1:40 AM
ALEFRAZIER
Sorry i changed the ignition control module not sensor and it does not need to be programed
Jul 25, 2016 at 7:54 AM
HMAC300
  • 48,601 POSTS
removing the fuses or disconnecting battery for anti theft does not work. scan for codes and check fuses under hood also check fuel pressure , see if it's getting spark etc.
Jul 25, 2016 at 8:07 AM
