Ignition electrical, no power when key turned to on position and will not start
200,000 MILES • 0.5L • V8 • 4WD • MANUAL
MOSCHAKMICHAEL
Bought this truck with push button start already in it. Drove it two months with no issues until today, turned it off and now no power when I turn key to on position and will not start. can jump solenoid turns starter but won't start. Pulled steering column apart, replaced ignition switch with no change. so I started checking for power with tester, have power at two yellow wires with key switch off but when turn key on no power anywhere in dash. Any help will be greatly appreciated.
Mar 1, 2019 at 8:36 AM
SCGRANTURISMO
  • 4,897 POSTS
You should always have power at the yellow wires going to your ignition switch. If you have no power from the switch on then I would think that the switch would be bad. Let us know what you find out.
Thanks,
Alex
2CarPros
Mar 1, 2019 at 6:00 PM
MOSCHAKMICHAEL
Power drops to 0 on everything including the yellow wires when I turn the key.
Mar 1, 2019 at 8:04 PM
MOSCHAKMICHAEL
Okay, figured it out. The connector to the clutch had come halfway unplugged .
Mar 1, 2019 at 9:26 PM
CARADIODOC
  • 34,415 POSTS
Allow me to add a comment of great value. The huge clue that was overlooked is you found 12 volts at a point, until you tried to get current to flow in that circuit by turning on the ignition switch, then it dropped to 0 volts. While this particular problem might not agree here, this type of problem shows up entirely differently when using a test light instead of a digital voltmeter. The cause is undesirable high resistance in the circuit. This is real common in radiator fan motor circuits that are protected by fuse link wires. When those burn open, they leave a carbon track behind, inside the insulation. That carbon will conduct enough current for a voltmeter to "see" 12 volts, . . . until you try to run the fan motor, then, that current causes the 12 volts to be "dropped" across the carbon, and you see the left-over 0 volts at the meter.
A test light works by having current flow through the bulb's filament, and since enough can't get through the carbon, the test light shows 0 volts whether the fan motor is turned on or not. That makes inexpensive test lights much more accurate for diagnosing this type of problem where there is not a definite break in the circuit.
You can equate this to standing on a garden hose and blocking 99 percent of it. A pressure gauge at the nozzle will still show full pressure as long as the nozzle is turned off. Turn that nozzle on and try to get some current to flow, and the little water will dribble on your shoes because the pressure has dropped to nothing. All of the pressure is being dropped across the resistance, or restriction, under your foot.
Had to share that wondrous story. Happy you found it and solved the problem.
Mar 3, 2019 at 9:23 AM
