Ignition cylinder
98,000 MILES • 3.3L • 6 CYL • AUTOMATIC
GABE D.
  • 10 POSTS
So I took off the original ignition switch and cylinder off my car, as I try to put it back together the cylinder will not go all the way in the ignition switch, it goes in but as I turn the cylinder it feels like only the cylinder is turning not the switch. what could be the problem? I know it fits because it is the same one I took off.
Nov 23, 2017 at 10:48 AM
  • 55,784 POSTS
Can you post pictures of the parts so I can see what is going on? I used to have one of these cars and it sounds like you do not have it timed correctly.
Cheers, Ken
Nov 24, 2017 at 10:24 AM
GABE D.
  • 10 POSTS
Yes.
Nov 24, 2017 at 11:16 AM
  • 55,784 POSTS
If that last picture in the switch it looks pretty worn out. These switches must be installed with the release pin pressed inward (paper clip). Have you replaced the switch by removing the bezel turn it counter clockwise?
Nov 26, 2017 at 4:49 AM
GABE D.
  • 10 POSTS
Yeah I already replaced it. I bought a new one yesterday.
Nov 26, 2017 at 5:29 AM
  • 55,784 POSTS
Hmm. can you make a video and upload here of the problem. It's hard to see what you are talking about.
Nov 26, 2017 at 6:26 AM
GABE D.
  • 10 POSTS
I was able to fix the problem with the ignition switch but the reason why I changed it was because when I try and turn on the car it won't start, I usually start the car in neutral but even then it won't click it won't do nothing, what I have to do now to start the car is by using a screwdriver and touching the 2 ends of the starter solenoid, I already replaced the starter solenoid and the ignition switch what else could be the problem?
Nov 27, 2017 at 11:11 AM
GMTECH
  • 537 POSTS
What year Mustang and auto or stic
Nov 27, 2017 at 11:22 AM
GABE D.
  • 10 POSTS
66 Auto
Nov 27, 2017 at 11:23 AM
  • 55,784 POSTS
It sounds like the neutral safety switch is shorted out. Here is a guide to help you confirm the failure so you can get it fixed. The switch is located on the transmission near the gear selector shaft.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
and
Cheers, Ken
Nov 28, 2017 at 4:43 AM
