Ignition cylinder swap
1,223,452 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
CHRIS RYAN2
I was wondering if I replace my ignition cylinder will my car start? my key has a transponder but the locking cylinder that I'm buying is not chipped will it work for my vehicle?
Oct 24, 2019 at 12:55 PM
  • 110,251 POSTS
Welcome back:
It will not start. The immobilizer will not receive a signal from the transponder to indicate the correct key is being used. Thus it thinks it's being stolen.
You need to get the correct type of lock and key and the key will then need programmed for it to communicate with the system.
Oct 24, 2019 at 1:46 PM
