Ignition cutoff
300 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
ROCCERO
Tried programming new remote for my car.
Put wire in four and eight heard three chirps pushed remote lock and unlock buttons.and turned key once to run .
Now car will not start and when I tried again putting in the jumper wire four and eight I do not get the chirping sound and car will not start. Dash lights come on but no start.
Jun 26, 2017 at 6:57 AM
SATURNTECH9
  • 30,869 POSTS
Why and when did you turn the ignition key the run position?You program the remote to the car with the ignition key off.I believe if memory serves correct when you turn the ignition key off and on a different amount of times you change the options for the anti theft.
Jun 27, 2017 at 2:44 PM
SATURNTECH9
  • 30,869 POSTS
Also are you sure you have the correct remote and the remote is working?
Jun 27, 2017 at 2:45 PM
ROCCERO
Found the problem must have put the paper clip in wrong pin and blew the fuse....10AMP. Old Eyes Lol
Thank You for your input
Jun 28, 2017 at 2:55 AM
SATURNTECH9
  • 30,869 POSTS
Oh blew the body fuse glad you found the problem.your welcome please tell all your friends about us.
Jun 28, 2017 at 3:28 PM
