Ignition control module location
1993 NISSAN SENTRA
165,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BEA ROMERO
  • 5 POSTS
Where do I find the ignition control module?
Feb 20, 2017 at 5:52 PM
WRENCHTECH
  • 20,761 POSTS
It is called a power transistor and it is mounted on the fender well, next to the master cylinder. https://www.2carpros.com/images/external/42131336.gif
Feb 20, 2017 at 7:49 PM
BEA ROMERO
  • 5 POSTS
What would cause no crank? just clicks head good starter, good battery, good ignition switch, will turn over on occasion. can push start, but will not start all the time with key.
Feb 20, 2017 at 8:42 PM
WRENCHTECH
  • 20,761 POSTS
Certainly not an ignition module.
Most likely a bad starter or connection problem in one of the battery cables.
Feb 21, 2017 at 4:47 AM
