Ignition Concern
135,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MICHAEL LABARBERA
  • 5 POSTS
I had a mechanic change the evaporator core to fix the air conditioner. Before the job, when I would turn the key off to shut off the car, it would always make several beeps. After the job was complete, when I shut off the car, there is no more beeping. I presume this is something important and I am concerned. Can you please shed some light on this concern?
Thank you,
Michael
Oct 17, 2016 at 1:38 PM
JIS001
  • 3,412 POSTS
The dash has to be removed for that job so most likely they forgot to plug the beeper back in?
Oct 17, 2016 at 1:59 PM
MICHAEL LABARBERA
  • 5 POSTS
Is that something to be concerned with? It beeps for a reason, but I am not sure what that reason is. Thanks for your reply.
Oct 17, 2016 at 2:07 PM
JIS001
  • 3,412 POSTS
It is a warning beep to let you know key is in the ignition, low on fuel, overheating, low oil, lights on etc... so it is helpfull to have.
Oct 17, 2016 at 2:32 PM
MICHAEL LABARBERA
  • 5 POSTS
Thank you!
Oct 18, 2016 at 10:48 AM
  • 55,770 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Oct 19, 2016 at 12:05 PM
