2003 Chrysler PT Cruiser A/C
RJC1942
  • 2003 CHRYSLER PT CRUISER
Air Conditioning problem
2003 Chrysler PT Cruiser 4 cyl Front Wheel Drive 142000 miles
I have no heat or a/c. Have changed thermostat twice. Cools at 60mph, but stops when standing.
Wednesday, February 25th, 2009 AT 5:14 PM
ZACKMAN
  • 4,202 POSTS
Usually ether you don't have heat (always cold, and you want heat) or you don't have AC (always hot, and you want cold). Which one do you wish to have?
Friday, February 27th, 2009 AT 1:17 AM
RJC1942
I would like to have heat. I recently had a new fan motor put in. Would that have something to do with it? Maybe? Thanks, rjc.
Saturday, February 28th, 2009 AT 7:17 PM
ZACKMAN
  • 4,202 POSTS
Well, fan motor helps blow the air, but here is some things that you need to check.
1. Enough coolant in the radiator, and the reservoir.
2. Good quality 50/50 coolant/water ratio. Less than 3 years, and no sludge.
3. Working thermostat.
4. Sealing radiator cap.
5. When was the last time you had the cooling system flushed? If it has been more than 2 years, that is too long. Perform one.
Saturday, February 28th, 2009 AT 11:22 PM
