Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daewoo
Lanos
Ignition
Coil
ignition coil
2002 DAEWOO LANOS
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ABU ALZAIN GHANNAM
MEMBER
my car has decreasing in mpg, did ignition coil is the cause, especially, because the car has interruption through slow speeds.
Dec 30, 2019 at 8:02 PM
Experienced Mechanic
Good morning,
Did you change the spark plugs as well?
Did you check the compression?
Dec 30, 2019 at 10:15 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
