ignition coil
2002 DAEWOO LANOS
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ABU ALZAIN GHANNAM
  • 11 POSTS
my car has decreasing in mpg, did ignition coil is the cause, especially, because the car has interruption through slow speeds.
Dec 31, 2019 at 4:02 AM
Good morning,
Did you change the spark plugs as well?
Did you check the compression?
Dec 31, 2019 at 6:15 AM
