Ignition and weird buzzing noise coming from fuse boxes?
2000 GMC SIERRA
233,330 MILES • 5.8L • V8 • 2WD • AUTOMATIC
SCOTT4891
Yes, I recently replaced the body control module BCM in my truck listed above 1500, now when I turn the truck to the on position weird buzzing noises come from instrument panel fuse boxes by brake pedal and under the hood.
I also had a diagnostic scanner hooked up to it when it was happening, and it made it back out turn off and on and restart.
Nov 28, 2022 at 7:25 AM
  • 55,433 POSTS
This can happen when the battery voltage is too low.
Here is a guide to help you test the battery without equipment:
If so, the battery fails, this guide can help walk you through the repair with instructions below for your truck:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Nov 29, 2022 at 1:47 AM
