Ignition replacement
117,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
CURTIS ROBERT
How to replace new ignition if the key will not turn it. I saw a video on how to replace it but they had to turn the ignition switch. Thanks
Apr 27, 2017 at 7:04 AM
STEVE W.
  • 15,411 POSTS
The easy way requires that the key be able to turn the existing lock cylinder. However are you SURE the problem is the key cylinder and not a bad ignition interlock solenoid or faulty transmission park switch? I would test those first as they are very common problems. Do you hear a click when you turn on the key and step on the brake? If you do the solenoid may be moving but not releasing the cylinder.
Apr 27, 2017 at 2:11 PM
CURTIS ROBERT
as stated before, the key does not turn. its all good though, a locksmith had to drill it out and replace the ignition switch. thx
Apr 30, 2017 at 10:56 PM
STEVE W.
  • 15,411 POSTS
Yeah, that is the "hard way" but it's very common these days. Seems like the lock cylinders these days are real junk compared to the old ones. I remember having ones that were so worn that just about any key worked, but they didn't get stuck...
Apr 30, 2017 at 11:12 PM
