disable the automatic engine pause?
105,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PETER THE EATER
  • 24 POSTS
How can I disable the automatic engine pause?
Nov 5, 2025 at 7:03 AM
  • 55,710 POSTS
Yep, that can be annoying and it wears the starter and flexplate out. Some GMs have a dash switch (an A with a circular arrow). If yours has it, you can turn Stop/Start off for that ignition cycle by pressing it each time; it re-enables next key-on by design.
Here is a quick hack that can work
At a stop, shift to L/Manual, tap + up to the highest gear (typically 6), then shift back to D. This prevents AutoStop until you shut the car off again.
Let us know how it goes.
Nov 6, 2025 at 1:36 AM
PETER THE EATER
  • 24 POSTS
I dont have a button and my shifter only has P R N D L . IS THERE A FUSE FOR IT MAYBE?
Nov 6, 2025 at 1:41 AM
PETER THE EATER
  • 24 POSTS
I do I disable engine pause?
Nov 6, 2025 at 1:48 AM (Merged)
PETER THE EATER
  • 24 POSTS
I found the L6 paddle shifting but it didn't help.
  • 55,710 POSTS
There is no fuse for this featured, it is built into the cars programming. You might able to find someone that can program the failure out of the car, I would search google for "car PCM programming" to see if you can find someone to do that for you, it should cost about $350.00. Please let me know how it goes.
Nov 6, 2025 at 1:50 AM
