Ignition swap?
2007 PONTIAC G6
100,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
SAVAGESHAFFER
i need to replace the ignition in my car listed above, and I'm wondering if an ignition from a Grand Am will fit in there and do the trick.
May 19, 2023 at 10:41 AM
  • 110,240 POSTS
If the Grand Am is the same model year, they are two different part numbers, so they are different.
Is it the actual switch that is being replaced or the key cylinder portion? I looked up the switch.
May 19, 2023 at 4:14 PM
