Ignition slight skip from start up
170,000 MILES • 2.0L • TURBO • AUTOMATIC
800ORANGES
I have a slight skip from start up till the engine gets warm. I have changed out the plugs and coil packs with ngks. Still has a skip.
Aug 5, 2026 at 5:07 AM
  • 55,694 POSTS
Yep, so you have a n engine misfire, so there should be a code pointing us to the correct cylinder which will help so here is a video to help to get us started.
https://www.youtube.com/watch?v=LBCpCWEFnTg
this video can help as well
https://www.youtube.com/watch?v=QTE8k06MzwQ
If you can upload a video of the engine running from under the hood it would help as well.
Aug 5, 2026 at 12:34 PM
