Will not start
90,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MOLLYDAD
  • 28 POSTS
I changed out starter but not starting, get dash lights and gauges and checked all fuses and relays. Could it be ignition switch? And how hard to change it?
Mar 25, 2018 at 9:31 AM
HARRY P
  • 2,292 POSTS
Could be the ignition switch. Could also be the range/PRNDL switch (that is a switch on the transmission that tells the computer what gear you have the transmission in). The car will not start if it is in any gear other than P or N. Try putting the car in N and see if it turns over. Also, try jiggling the shifter when turning the key. If that does not do it, then we will go through the diagnostics process together.
Mar 25, 2018 at 12:37 PM
MOLLYDAD
  • 28 POSTS
Tried that, no go yet.
Mar 26, 2018 at 1:19 AM
HARRY P
  • 2,292 POSTS
Is the security light on?
Mar 26, 2018 at 11:46 AM
MOLLYDAD
  • 28 POSTS
Got it to a shop, apparently my negative battery cable came loose and did something to the security thing on computer, had to get it reset.
Mar 26, 2018 at 11:59 AM
HARRY P
  • 2,292 POSTS
Oh lord I love it when it is something simple like that. I hope it did not cost too much to get that done.
Mar 26, 2018 at 12:01 PM
MOLLYDAD
  • 28 POSTS
About $175.00, but $85.00 of it was the tow. Thanks for the help though.
Mar 26, 2018 at 1:37 PM
MOLLYDAD
  • 28 POSTS
Had a problem with my car not starting awhile back, had it towed to shop, they said it was some kind of security lock out and they reset something but did not tell me what they did. Now it is doing it again and I tried the ten minute battery thing I saw online but no go. Help?
Aug 7, 2018 at 12:19 PM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Here is a relearn/reset instruction for your car. I have also attached a link for general how-to reset procedure. Hope this helps!
Danny-
https://www.2carpros.com/articles/how-to-reset-a-security-system
MOLLYDAD
  • 28 POSTS
Which fuse is it? It does not say in the owners manual which one .
DANNY L
  • 5,648 POSTS
Here is a test procedure for your anti-theft system. Do you have access to a diagnostic code scan tool? Did you try the Oldsmobile factory reset I provided? I will look to see if I can find your anti-system fuses. Danny-
MOLLYDAD
  • 28 POSTS
Doing the not start thing again and security light still flashing.
