Engine does not crank with the key in the on-position?
167,940 MILES • V6 • 2WD • AUTOMATIC
MUSTANGGUY1620
Car won't crank with key in the on-position lights do come on the dash and radio. replaced the starter that wasn't the problem. if I jump it can crank it by switching the key to the on position and touching Two bolts on the start with a screwdriver, even after that rare but it will sometimes randomly stop running and just cut off completely.
Feb 28, 2023 at 11:32 PM
  • 110,248 POSTS
Do you mean the starter won't engage when the key is in the start position? If that is the case, take a look through this link first to see if it helps.
If that doesn't help, see if it will start in reverse. If there is no change, I need you to check fuses and the starter relay.
If you look below, I attached the starting circuit wiring schematic. Start by testing the start fuse in the battery junction box (fuse 19). Also, check fuse 27 in the smart junction box under the dash.
In addition to checking the fuses, confirm there is power to and from them.
If the fuses are good and have power, switch the starter relay with a different one in the box having the same part number. If there isn't one, here is a link that explains how to test a relay:
Let me know what you find.
joe
See pics below. Note: The last two pics show fuse and relay locations. Pic 1 is the BJB, and pic is the SJB.
Mar 1, 2023 at 12:08 PM
