Hello, I am Danny.
After replacing the fuel pump did you test at the Schrader valve on the fuel rail to see if it is working/getting pressure? Fuel pressure should be between 55-65 P.S.I. If you do not have a fuel pressure tester your local auto parts stores (AutoZone, Pep
Boys,O'Reilly's) have a loaner program and will rent you one. I have attached a tutorial showing what is involved. Hope this helps and feel free to ask any questions.Thanks for using 2Carpros.
Danny-
Sep 16, 2018 at 4:54 AM
