Ignition
117,281 MILES • 4WD • AUTOMATIC
JEWEL HAWKINS
my key won't turn over but lights and all are on and I can't get my key out of the ignition
Dec 23, 2015 at 6:43 AM
RYAN L
  • 273 POSTS
So the key is stuck to the 2nd position? If it is try rocking the wheel back and forth vigorously while trying to rock the key back and forth. This should give you enough space for the ignition to wiggle its way back to the 1st position and you can remove the key.
Dec 23, 2015 at 6:47 AM
JEWEL HAWKINS
Not working and I can't get my car to start now, but lights radio wipers R all working
Dec 23, 2015 at 6:52 AM
RYAN L
  • 273 POSTS
This either means the ignition mechanism has malfunctioned and needs to be replaced or the wheel lock for the ignition is locking when it shouldn't be.
Dec 23, 2015 at 7:27 AM
